Snowyowl123 Posted July 26, 2009 Share Posted July 26, 2009 Any body help? When driving steadily around in my 94 3.0 n/a aero evrythings fine but as soon as i open her up and give it some revs the red warning triangle light and yellow engine warning lights come on.If i then stop and shut off the ignition and restart evrythings ok again.Engine and transmition oil levels are spot on.Any ideas? Also how do I tellwhat brake pads i need...car is a 94 import.Thanks in advance. Link to comment Share on other sites More sharing options...
Ian C Posted July 26, 2009 Share Posted July 26, 2009 Check for error codes My guess is it's your No1 Vehicle Speed Sensor. Is the car converted to read MPH on the speedo? Does it go past 112mph? Dodgy convertor/delimiters are by far the most common cause of such a problem. -Ian Link to comment Share on other sites More sharing options...
Snowyowl123 Posted July 27, 2009 Author Share Posted July 27, 2009 Mr IanC i cant thank you enough.Top link and as you diagnosed fault code 42 was found.Is the car ok to drive and what is the cure?A dodgy delimiter you rekon? Where is it and are they easy to replace? Sorry for all the questions...dense newbies have to learn somehow! Andy Link to comment Share on other sites More sharing options...
Homer Posted July 27, 2009 Share Posted July 27, 2009 Error 42 is nearly always a badly wired (or cheap ebay) speedo convertor or delimiter. The first thing to do is try and answer a few of the questions Ian mentioned (if possible), failing that, remove the dash panels and see what you have wired into the plug that goes into the back of the speedo cluster. Link to comment Share on other sites More sharing options...
Snowyowl123 Posted July 27, 2009 Author Share Posted July 27, 2009 both speedo and odometer read in MPH.Havnt tried to go past 112mph yet! Link to comment Share on other sites More sharing options...
Homer Posted July 27, 2009 Share Posted July 27, 2009 both speedo and odometer read in MPH.Havnt tried to go past 112mph yet! Well I wouldn't recommend you try it, obviously Can you take a look at what's wired in behind the dash and if possible take some good pictures of anything that is spliced into the speedo and odo plugs, plus where they connect to (Should be a little black box somewhere around there!). It'll really help diagnose the source of the error. Link to comment Share on other sites More sharing options...
