The Raven Posted May 17, 2009 Share Posted May 17, 2009 My cruise only works at 70mph or below? Any ideas? Not that i ever go over 70mph. I found this out while a track day.................. Quote Link to comment Share on other sites More sharing options...
TrickTT Posted May 17, 2009 Share Posted May 17, 2009 Badly fitted (or cheapo) speedo converter. Probably just needs wiring in properly. Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 17, 2009 Author Share Posted May 17, 2009 Badly fitted (or cheapo) speedo converter. Probably just needs wiring in properly. I thought so, i have a speedo converter Quote Link to comment Share on other sites More sharing options...
TrickTT Posted May 17, 2009 Share Posted May 17, 2009 Standard j-spec cruise only works up to 110km/h. Take the signal from the speedo converter to the cruise ecu which is behind the dash on the left of the steering column and you will have cruise that works up to 110mph. Quote Link to comment Share on other sites More sharing options...
hadyn Posted May 17, 2009 Share Posted May 17, 2009 Would feeding the cruise control ECU a signal from a top speed delimiter do the job too? Quote Link to comment Share on other sites More sharing options...
