Scooter Posted May 3, 2009 Share Posted May 3, 2009 Can any NA (in particular) facelift owners let me know whether they have a low oil warning symbol that lights up on ignition. It doesn't light on mine but then i've got a feeling it never has from new and i'm starting to think the later na's have no low oil sensor. Link to comment Share on other sites More sharing options...
ShamelessTT Posted May 3, 2009 Share Posted May 3, 2009 Have you checked its not the classic dry joint issues? (i for one had that, along with many others. Im TT) Link to comment Share on other sites More sharing options...
Mike Posted May 3, 2009 Share Posted May 3, 2009 I'm thinking not... but I'll check for sure next time I drive it Link to comment Share on other sites More sharing options...
Faye Posted May 3, 2009 Share Posted May 3, 2009 The red can lights up, but the can symbol to the right of it with squiggles underneath doesn't. Link to comment Share on other sites More sharing options...
Scooter Posted May 3, 2009 Author Share Posted May 3, 2009 (edited) The yellow can lights up on pre facelift na's though....... Faye can you check if you don't have the usual sensor too See pics here.... its right down low on the engine/top of the sump, to the right of the oil filter if looking in from the passenger side.... Edited May 3, 2009 by Scooter (see edit history) Link to comment Share on other sites More sharing options...
Dave Posted May 3, 2009 Share Posted May 3, 2009 none of mine lit up till heckler sorted the joints and only one oil light lights up Link to comment Share on other sites More sharing options...
Scooter Posted May 3, 2009 Author Share Posted May 3, 2009 none of mine lit up till heckler sorted the joints and only one oil light lights up Well this thread would suggest that yours may not be totally ok still? Basically mine is a later car and i'm 99% sure its solder is ok, I found the usual oil level sensor is missing, so i think the combination of these two things means that my later car has no and never had any means to flag up low oil level so i'm trying to find others that may be the same to confirm this. Dave, i suspect your car does not have the green blanking plug in the attached picture of my sump, I suspect you have a electrical connector as afaik all pre facelift and all tt's pre or post facelift have...... Link to comment Share on other sites More sharing options...
Faye Posted May 3, 2009 Share Posted May 3, 2009 Mine looks the same as yours Link to comment Share on other sites More sharing options...
Scooter Posted May 3, 2009 Author Share Posted May 3, 2009 ah good...........in a way. Seems odd that for some reason toyota stopped bothering to include it? cost cutting? Link to comment Share on other sites More sharing options...
