None supra friend car issue (vids included)
ShamelessTT
Hi all,
Just quick request if anyones got time to check out my friends issue with his car, and might hazard a guess at what it is.
http://s654.photobucket.com/albums/uu262/muld/?action=view&current=Movie.flv
The best sound of the issue is just before the end of the video. The sound comes from the passenger side, lower foot well.
An issue has been suggested by two local garages (but they have only heard / driven it. If anyone comes up with it, it will confirm what they are saying.
It happens, both in gear and out and sound changes with speed!
(We have elliminated wheel bearings, anything catching and have a good look around underneath and cant see anything obvious.)
Cheers,
Simon
Hi all,
Cheers,
Simon
Gearbox?
just going by what happend to my dads car, got a noise/vibration from the back of the car, replaced the wheel bearings, rebuilt the diff, replaced the prop, turns out it was the gearbox...
They have suggested "Diff" failure is pending, so both garages have suggested fitting a new gear box , diff , and clutch.
My question is why gear box, if its the diff? maybe its one unit? (Renault Clio Cup 172 Ph2)
Expensive!!
Open the diff and check the teeth on the crown wheel. cheap and eliminates the diff. Can you really feel it through the car or is it just a noise?
Its just a noise, car drives fine, pulls well and gears go in easily. Noise has been getting louder over the last week or so. (Used to be only when in gear, now its both).
Check the crown wheel of the diff, As this will make this sort of sound. BUT. Without actually driving the car I'm not going to commit. Although this was on a rear wheel drive car, so checking this will not be cheap as said earlier. Being french I'd say the gearbox/diff has shit itself.
I would also pop a driveshaft out and check for roughness in movement first!
Check the crown wheel of the diff, As this will make this sort of sound. BUT. Without actually driving the car I'm not going to commit. Although this was on a rear wheel drive car, so checking this will not be cheap as said earlier. Being french I'd say the gearbox/diff has $#@! itself.
Cheers the suggests are much appreciated :)
