Drivers side rear hub
probrox
I'm looking for a drivers side rear hub with bearing. I've had a nasty noise coming from mine but I can't afford new parts at the moment.
Is there anything else which could be causing the noise? It is a grinding noise which occurs once in each rotation of the wheel. I replaced the same hub back in November and it was fine for a while but has now started again, so I wasn't sure if there was anything else which could be causing this or if the one i bought was just already on its way out.
