Second Turbo Issues
SupraJames
I seem to be having a prob with my second turbo, was fine till I switched back from TTC to sequential. First turbo comes in fine and pulls good boost, get close to 4000RPM and engine note changes like second turbo is going to cut it but then it does not come in with any power and pulls around 0.4-0.5 bar boost, when I should be hitting 1.1 bar. Checked all hoses and all are ok, checked to see if the actuator is movable and not stuck and all is ok.
Remember hearing a similiar prob with second turbo when going back from TTC mode.
Also noticed that the small black plastic vented knob has come off the end of the second turbo VSV value, is this a problem..?
Hope that post makes sence and hope someone can help.
  • 6 months later...
