Paul372 Posted April 5, 2009 Share Posted April 5, 2009 Hi, i'm getting a loud clunking noise from my steering when i'm doing a maneuver when the steering is near on full lock and i also get the same noise when i'm hard on the brakes and the same noise but not as loud when i rock the steering wheel back and forth, could this be steering ball joint or something Link to comment Share on other sites More sharing options...
imi Posted April 5, 2009 Share Posted April 5, 2009 Sounds like your front sub-frame needs to be tightened (fairly normal on supras). Do a search for more details, there should be diagrams about what it looks like and what needs to be tightened and by how much. Link to comment Share on other sites More sharing options...
Nic Posted April 5, 2009 Share Posted April 5, 2009 As said it'll either be loose sub frame or suspension arm bolts. Torque settings here http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf Link to comment Share on other sites More sharing options...
Paul372 Posted April 6, 2009 Author Share Posted April 6, 2009 thanks guys i will take a look and tightened them up Link to comment Share on other sites More sharing options...
Paul372 Posted April 7, 2009 Author Share Posted April 7, 2009 is there a part on the end of the steering rack you can change Link to comment Share on other sites More sharing options...
