problem half solved !
wilkorangerover
This sounds very much like my problem i had with the aristo. Does it seem like its stumbling or hesitating hugely on hard accells? When mine was doing that it turned out to be the fuel pump had pushed off the fittings and i wasn't getting full fuel pressure at the rail. Might be worth a check
there is a set up procedure for the TPS Chris Wilson set mine up so he may be a mine of information on that front
all fixed by myself (saved a potential big bill)
i just had to reset the hks f-con pro and link it up to my throttle position sensor(30 second job)
when crusing round the afr is 12.4
soon as you floor it its 10.9
so happy, its been getting me down ,
ps no more playing with ecu switches ;)
japfest here we come (hopefully bringing the t88 supra as well)
The garage (dicksons, perth) i bought her from had put standard plugs in the car :(
now with the right plugs/new oem o2 sensor , it seems to go a lot better!
Edited by wilkorangerover (see edit history)
