BlackWatch66 Posted February 14, 2009 Share Posted February 14, 2009 I am going BPU and need to get a boost controller. I understand that there are manual mechanical boost controllers and electronic boost contollers, obviously the latter being much more expensive. How does everyone rate the mechanical BC's and is there any problems with them over the EBC's? Link to comment Share on other sites More sharing options...
JamesC Posted February 15, 2009 Share Posted February 15, 2009 If your J-spec you shouldn't need a boost controller, just a restrictor ring..... if i'm right Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 15, 2009 Share Posted February 15, 2009 If your J-spec you shouldn't need a boost controller, just a restrictor ring..... if i'm right Correct, unless he's TTC in which case he'll need a boost controller. The mechanical boost controllers aren't the best in terms of accuracy but I believe there are a few people on here using them with no problems at all. For the extra flexibility and smoother torque curve I'd get the electronic one TBH. Link to comment Share on other sites More sharing options...
Homer Posted February 15, 2009 Share Posted February 15, 2009 If your J-spec you shouldn't need a boost controller, just a restrictor ring..... if i'm right Yep A restrictor ring is all thats needed for the jspec. manual boost control is not a good choice, but there are plenty of options out there for good EBC's. Take a read: bpu Edit - haha, even at this time of the morning you get sensible replies Link to comment Share on other sites More sharing options...
trinitom Posted February 15, 2009 Share Posted February 15, 2009 Yep A restrictor ring is all thats needed for the jspec. manual boost control is not a good choice, but there are plenty of options out there for good EBC's. Take a read: bpu Edit - haha, even at this time of the morning you get sensible replies so the best way to control the boost in jap spec, is an electronic BC? I'm a bit lost in this matter! if i have a j spec decated with ring restrictor, do i need a electronic or manual bc? thanks.. Link to comment Share on other sites More sharing options...
couv3z Posted February 15, 2009 Share Posted February 15, 2009 so the best way to control the boost in jap spec, is an electronic BC? I'm a bit lost in this matter! if i have a j spec decated with ring restrictor, do i need a electronic or manual bc? thanks.. by what homer has said and the bpu you should only need the rr, but..... from what i under stand you can 100% say the RR will gie 1.2bar it could be 1.1 or 1.3 Link to comment Share on other sites More sharing options...
trinitom Posted February 15, 2009 Share Posted February 15, 2009 by what homer has said and the bpu you should only need the rr, but..... from what i under stand you can 100% say the RR will gie 1.2bar it could be 1.1 or 1.3 if i want to install an electronic BC (Blitz Dual SBC DSBC) in a j spec fully decated with RR, and run 0.8 most of the time will this be ok or wrong? Link to comment Share on other sites More sharing options...
aido Posted February 15, 2009 Share Posted February 15, 2009 if i want to install an electronic BC (Blitz Dual SBC DSBC) in a j spec fully decated with RR, and run 0.8 most of the time will this be ok or wrong? You'd need a restrictor ring with a smaller than normal hole I think to make sure the car stays at 0.8 bar - the boost controller can only up the boost - not limit it. Link to comment Share on other sites More sharing options...
