Gazboy Posted February 4, 2009 Share Posted February 4, 2009 A lot of replies are blocked but has anyone mentioned checking the subframe bolts are tight yet? Isn't that an old wives tale? To the OP, what condition are the tyres in, what make are they and make sure you have the correct pressures. No point going any further untuil this is known imo. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted February 4, 2009 Share Posted February 4, 2009 Ide check the top wishbone bushes too, they're common to go on supra's mine felt a bit wobbly, failed mot on the bushes, replaced the wishbones and it was 10times better! Quote Link to comment Share on other sites More sharing options...
SpeedyAndy Posted February 4, 2009 Share Posted February 4, 2009 Hi Andy Listen out for any knocking on turning or acceleration as this could indicate suspension problems. Hiting speed bumps won't do your alignment much good either. Check for wear patterns on the inner/outer tyres, anything excessive could indicate tracking is out I don't think alignment checks are covered in general service so maybe get it checked out somewhere that knows their stuff. These cars cars have twitchy rears anyway, as has been said A harder compound tyre won't grip so well in the wet/damp causing the rear to snake around. If the suspension gets the all clear a good set of sticky rubber may be useful - Toyo proxes T1R's are excellent others here may have suggestions. What tyres do you have currently by the way?? Linda x Hey Linda, Now your a women that knows stuff lol many Thanks for the info. I think when the snow goes ill get out there and jack her up and check every think all over. Thanks again Linda for info Quote Link to comment Share on other sites More sharing options...
Guest knd Posted February 5, 2009 Share Posted February 5, 2009 thanks for your hlep ill get some good tyres and the geomtry sorted out and see if its any better and thanks for help with my spelling jonny g lol Quote Link to comment Share on other sites More sharing options...
