Batmax Posted January 29, 2009 Share Posted January 29, 2009 Hi Squeaking on the front what could be ? the Squeaking comes fron the side of Ac could be the belt anyone have these Squeaking, after the car stops to warm up the noise. Link to comment Share on other sites More sharing options...
miko_supra Posted January 29, 2009 Share Posted January 29, 2009 Cold belt squeeking sounds normal. Just replace it Link to comment Share on other sites More sharing options...
Missile Posted January 29, 2009 Share Posted January 29, 2009 Cold belt squeeking sounds normal. Just replace it If you try this and it does not sort the problem, Check your crank pully, I've no idea what mine did, But it broke and made a sqeeking noise, Espesially if i turned the air con on, But when the car was warmed up its died right down Link to comment Share on other sites More sharing options...
keron Posted January 29, 2009 Share Posted January 29, 2009 could be the pas pump front bearing...usually a common noise that can happen...tends to do it when cold... Link to comment Share on other sites More sharing options...
w41k3r Posted January 29, 2009 Share Posted January 29, 2009 dunno wether you should but i had a squeaky belt i sprayed wd40 on mine and it went Link to comment Share on other sites More sharing options...
Batmax Posted January 29, 2009 Author Share Posted January 29, 2009 Hi yes if I spray on the section of ac the noise go, so maybe be the belt ? Link to comment Share on other sites More sharing options...
Batmax Posted January 29, 2009 Author Share Posted January 29, 2009 where I can buy one because in my country is very expensive anyone know ? Link to comment Share on other sites More sharing options...
4packet Posted January 29, 2009 Share Posted January 29, 2009 Expensive here too mate. Get a Gates or similar motor factor part. I was able to look up the part in their catalogue. Link to comment Share on other sites More sharing options...
Batmax Posted January 29, 2009 Author Share Posted January 29, 2009 One more question , I am think to take of the belt to see if the noise stop. Should I need to do any mod or I just can take off the belt (simple) and put again? Or it's better bring to the garage ? Link to comment Share on other sites More sharing options...
Missile Posted January 29, 2009 Share Posted January 29, 2009 Don't think taking the belt of and driving would be such a good idea mate. If its the belt i'm thinking of the steering would be very hard, The water would not be getting pumped alternator etc etc etc.. Link to comment Share on other sites More sharing options...
Batmax Posted January 29, 2009 Author Share Posted January 29, 2009 I mean test just at idle lol Link to comment Share on other sites More sharing options...
Missile Posted January 29, 2009 Share Posted January 29, 2009 Ha Ha. Sorry, Imagined you out driving around etc. Still unsure its a good idea. Someone with better know how will confirm i'm sure. Link to comment Share on other sites More sharing options...
3LL Posted January 29, 2009 Share Posted January 29, 2009 if your talkin bout the auxiliary belt your best off getting it replaced, and also check the crank shaft pully at the same time for wear, if this spins off at high speed it can wipe out half your engine bay as its bloody heavy! Also As Keron suggested check the AC pump as these are known to Seize. Link to comment Share on other sites More sharing options...
