DAT Inter Posted January 16, 2009 Share Posted January 16, 2009 Hey there guys. I had a rummage using the search button, , but couldnt find a guide or anything. Im going to be putting my coileys on tomorrow, Driftworks HSD's, and am just looking for a guide/advice/step by step etc. Is it simply, undo the top three bolts, remove the bottom bolt then pull out? Cheers for the help. Fraser Link to comment Share on other sites More sharing options...
Scooter Posted January 16, 2009 Share Posted January 16, 2009 click here for a guide for the rears Link to comment Share on other sites More sharing options...
Homer Posted January 16, 2009 Share Posted January 16, 2009 The rears are easy (even easier with Ian's link above) The fronts are a little more tricky as the lower arm normally needs to come out to get the stock coilover out. I've never had a problem getting the bolts out but some people have done. Not directly related, but some pics here from Carlos's rusty old UK: http://www.mkivsupra.net/vbb/showthread.php?t=48973 Link to comment Share on other sites More sharing options...
DAT Inter Posted January 16, 2009 Author Share Posted January 16, 2009 Cheers guys. No guides for the front kicking about? Cheers Link to comment Share on other sites More sharing options...
Homer Posted January 16, 2009 Share Posted January 16, 2009 Cheers guys. No guides for the front kicking about? Cheers I can't recall seeing one but let me know if you find one Otherwise I'll create one next time the front shocks are changed -or you could create your own when doing the swap Link to comment Share on other sites More sharing options...
DAT Inter Posted January 16, 2009 Author Share Posted January 16, 2009 Will try and do one for the whole thing. Fuck, not looking forward to doing the front ones now lol. Itsa fresh import so bolts shouldnt be too bad. Link to comment Share on other sites More sharing options...
Homer Posted January 16, 2009 Share Posted January 16, 2009 Will try and do one for the whole thing. Fuck, not looking forward to doing the front ones now lol. Itsa fresh import so bolts shouldnt be too bad. If you can move some spanners and a lump hammer you'll be alright, it's really not difficult, just a little frustrating *if* bolts are seized up. Just take your time and it'll be fine If you can manage to do the rear shocks you can do the front ones, there's no leap of knowledge or skill needed. If you're moving camber items, just make sure you mark them up before removing. Link to comment Share on other sites More sharing options...
DAT Inter Posted January 16, 2009 Author Share Posted January 16, 2009 Cheers Homer. Link to comment Share on other sites More sharing options...
GreaseMonkey Posted January 16, 2009 Share Posted January 16, 2009 (edited) This Info might be Helpful for the Front and Rear Suspension and is from the Toyota supra jza80 Chassis Body Manual so no need to remove the lower arm and wheel arch liners hopefully . http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf Oops I forgot to add the sections you would need are pg SA-20 for Front Suspension and SA-90 for Rear Suspension. These will also include the torque settings as well. Edited January 16, 2009 by GreaseMonkey (see edit history) Link to comment Share on other sites More sharing options...
JustGav Posted January 16, 2009 Share Posted January 16, 2009 (edited) It is an easy job.... It does help to have two people, but I've done a few sets on my own. (Roughly a two hour job if you have a bit of gusto, 30 min per corner) Spring compressors are very handy to have and make the job a bit easier Rears, easy enough, one bolt at the bottom, three on top, use spring compressors and pull out as one unit. Fronts, drivers side is easy enough, pull out the long bolt from the top wishbone, move it out the way, undo the bottom bolt from the unit, and remove. Passenger side is the same, however you need to move the washer bottle as well in order to slide the bolt out completely. There is nothing else to dismantle before you start taking ARBs and all the malarky out EDIT : You will need to move the arch liners out the way for the long top wishbone bolts. Edited January 16, 2009 by JustGav (see edit history) Link to comment Share on other sites More sharing options...
DAT Inter Posted January 16, 2009 Author Share Posted January 16, 2009 so no need to dismantle the arbs etc? Link to comment Share on other sites More sharing options...
JustGav Posted January 16, 2009 Share Posted January 16, 2009 so no need to dismantle the arbs etc? Noooooo..... Link to comment Share on other sites More sharing options...
