AVCR Gear Judge
Jellybean
Those are the rpm to speed ratios. It works out what gear you are in by revs/speed, but you train it first by driving at a set RPM in those gears. Can't remember the specifics, the instructions tell you how to set it up.
A handy hint from supraforums, as the AVCr only has entries for 5 gears, is to treat your 6th as its 5th, your 5th as its 4th etc down to 2nd as 1st. You'll never need to trim 1st gear boost levels on these cars :D
-Ian
-Ian
Thank you
Also found this very useful Supra specific artical
http://www.mkivsupra.net/vbb/showthread.php?p=2216737#post2216737
