MP3 Tagging Software?
Tricky-Ricky
I have one for iTunes that I promised Pete I'd tell him the name of about two years ago!?
I'll have a look tonight and let you know...
This only works in iTunes, mind... It updates tracks, album title, art work, the lot :)
Sounds good, I'd be interested in that too:)
Still not sure what you're trying to do, in particular what your starting point is. You mentioned duplication, but what is in danger of being duplicated? The actual MP3 files, or tag text within files, or something else?
Are you starting from a collection of unorganised MP3 files on your computer? Or are you looking for something to create the MP3s in the first place, and tag them in the process?
Hmmm. It should be possible if the names of the MP3 files correspond to what you want the tags to be. For example, a file called "Kylie Minogue - Two Hearts.mp3" could be interpreted by some software (I don't know of any off-hand, so I'm not being very useful here :(), but only if the filename for all your MP3s follwed the same naming convention. If they don't, any software you hit it with would have no way of knowing what the artist/title is.
Update: just looked on Google (searched "set mp3 tags according to filename"), and found this:
http://jay-jay.net/src/perl/mp3ManagementSuite/mms-filename2tag.html - if a command-line prompt puts you off, this might not be for you.
http://www.softpointer.com/tr_help/02.03_How_to_get_tags_from_file_names.htm - not sure if it's free or not.
Tag and rename, the one in the link i provided, has a few options for automatically renaming the id3 tags. The best uses the existing filename and a macro that you set up to pick out the individual words. For example:
Filename: metallica-master_of_puppets.mp3
You would create a macro (easy to do in the program) that recognises metallica as the Artist, it replaces the "_" with spaces and converts all the 1st letters to capitals. It also would recognise the "master of puppets" bit as the title. Then there are options for chaning the album title to all the files at once, as well as adding track numbers. Its really hard to explain on here but download the programme and have a play around, its really good...and free.
Well i finally had the best results with Winamp, BUT! there is always a drawback, when you copy the Winamp playlist to a folder or USB stick, it is a M3U file (.m3u) and not in folders, and will only open with WMP, i dare say i could change that but even so I'm not sure it will play via a head unit.
  • 3 weeks later...
id3 tagit, is my weapon of choice...
http://www.id3-tagit.de/
It does multiple edits, for example setting a group of files to the same artist. Supports v1 and v2.
Does suffer a little bit with files if they are broken, but to be fair not very often.
It also allows you to do filename->mp3 tag or mp3 tag -> filename.
Whilst loading my phone up with some audio enjoyment the tags were all over the place. That has sorted them out nicely. Thanks Gav :)
