greddy egt gauge
wilkorangerover
I got EGT gauges but i hav't fit it yet! Im still trying to found out how to put fit the sensor, im bit worry if i drill on manifold and it will knack my turbo?
I think Chris wilson can fit the egt gauges i guess
hi my friend has found a greddy egt gauge in his single turbo supra he has just bought, it was just in the passenger side footwell, so he s plugged it into the little on/off box, but the needle stays on 9 even when the engine is of, so iam guessing the needle is knackered???
cheers
im guessing it has peak hold and a small control box? if so it will need wiring in to say cigarette lighter to give it some power before it will work, its just a matter of connecting a few wires up though.
-robert-
  • 2 weeks later...
cheers
Shouldnt stay in that position, could be bad. Get a volt meter and run some test on the gauge. If you get current then maybe its something else.
It should be at the bottom and read EGT when applying throttle.
I have one in stock if you need another.
Thanks,
Joe
