bamboo rocket Posted October 11, 2008 Share Posted October 11, 2008 Hallo I own a facelift TT from November 1996. My question is does it have the OBD-1 or OBD-2. How can I check? Thanks Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 11, 2008 Share Posted October 11, 2008 more than likley to be obd2 , i think they wer all ob2 after 96 Link to comment Share on other sites More sharing options...
Nic Posted October 12, 2008 Share Posted October 12, 2008 I'm not 100%, but I think only the VVTi is OBD2. The non-VVTi facelift I believe is still OBD1 Link to comment Share on other sites More sharing options...
merckx Posted October 12, 2008 Share Posted October 12, 2008 The VVTI car doesn't have a particularly common OBD II protocol, so not all fault code readers will work. It has an OBD II labled port on the panel down under the steering wheel. You may be able to read some codes yourself using this method on the diagnostics port in the engine bay. You'll be bridging either E1 and TE1 or Tc and E1. http://www.mkivsupra.net/vbb/showthread.php?t=35920 Link to comment Share on other sites More sharing options...
