little num Posted September 7, 2008 Share Posted September 7, 2008 hey all im after a fuel cut defender as i bought a greddy from jody t and he seems to have forgot to tell me that they are not compatible with the UK spec (not sure why). so if any 1 has a fcd for sale pm me or text me on 07809 627560 cheers james. Link to comment Share on other sites More sharing options...
jamesmark Posted September 7, 2008 Share Posted September 7, 2008 I thought the Greddy ones were universal ish) as they fit MR2's too, so should have been ok for a UK spec. Have you set it correctly? As Greddy units are not preset. I am sure someone will confirm for sure though. Link to comment Share on other sites More sharing options...
little num Posted September 7, 2008 Author Share Posted September 7, 2008 I thought the Greddy ones were universal as they fit MR2's too so should have been ok for a UK spec. Have you set it correctly? As Greddy units are not preset. I am sure someone will confirm for sure though. i havent fitted it as yet i was looking for some instruction on here and found a link another guy had posted saying he bought the same greddy fcd and it says on the box FOR JAP SPEC ONLY, he also asked what would it do if fitted but nobody replied so still none the wieser at present, i did find some instuctions but they aint very clear, need to know what wire is the boost wire for the ECU. Link to comment Share on other sites More sharing options...
jamesmark Posted September 7, 2008 Share Posted September 7, 2008 With all due respect mate I think you should have attempted to find out if it will work before naming someone, your advice thread might have had more luck than the other one. Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted September 7, 2008 Share Posted September 7, 2008 if you want to sell the greddy give me a shout Link to comment Share on other sites More sharing options...
little num Posted September 8, 2008 Author Share Posted September 8, 2008 With all due respect i did find out that it wouldent work on a UK car, and im not going to fit it just incase it throw's the ECU light up and i cant reset it, ive had 2 PM's also saying it wont work, so im after a thor or somthing tried and tested on a uk model. Link to comment Share on other sites More sharing options...
jamesmark Posted September 8, 2008 Share Posted September 8, 2008 Fair enough, I would double check the wiring as the Greddy unit and the Thor unit use the same wiring (I have fitted both). Shame those 2 people could not give advice in the thread rather than PM, so that their knowledge can help people in the future. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 8, 2008 Share Posted September 8, 2008 It'll fit a UK car, you can see fitting instructions here http://mkiv.com/techarticles/bcc/bcc_install/bcc_intro.htm if you need them. Link to comment Share on other sites More sharing options...
jamesmark Posted September 8, 2008 Share Posted September 8, 2008 It'll fit a UK car, you can see fitting instructions here http://mkiv.com/techarticles/bcc/bcc_install/bcc_intro.htm if you need them. If that is the case and Paul does sell and fit these, I think someone needs to apologise to Jody. I thought they were the exact same, kinda worrying the 2 tech guys by PM. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 8, 2008 Share Posted September 8, 2008 I dont think we've ever fitted one to a UK car here but its all in black and white on the mkiv.com Link to comment Share on other sites More sharing options...
jamesmark Posted September 8, 2008 Share Posted September 8, 2008 I dont think we've ever fitted one to a UK car here but its all in black and white on the mkiv.com Personally I would set the Greddy up using a volt meter to 1.2bar and fit it, it is not going to cause harm except fuel cut. Link to comment Share on other sites More sharing options...
JODY T Posted September 9, 2008 Share Posted September 9, 2008 Just seen this... That Greddy Unit is the correct one for the car... Wouldnt sell you rubbish bud.... Link to comment Share on other sites More sharing options...
mark uk manual Posted September 9, 2008 Share Posted September 9, 2008 i had one of these on my old uk car. Link to comment Share on other sites More sharing options...
ADL Mark Posted September 10, 2008 Share Posted September 10, 2008 I've got one on my UK car working fine and never caused a problem. Don't jump the gun fella, Jody won't sell you what you don't need. Link to comment Share on other sites More sharing options...
