Stock paint thickness?
Guest KDW
I can't believe you need to know this? if the respray is not 'thick enough' are you going to go back to the sprayer and insist on a few more coats?
That is exactly what I will do yes!
Or actually I will check it on the spot and if it's not what I expect it do be, he wont get a dime.
I want to make sure he did as many layers as agreed upon.
A mirror-like, showcar finish is what I'm after.. Otherwise I wont pay him.
I think it's all good though, he seems to be a good chap. (but just in case..)
so have you gone over the whole car taking readings of the paint depth?
unless you have or unless they take the whole car back to bare metal you wont be able the tell how much paint has been applied,also any areas that have filler in will go off scale on the micron gauge
a mirror like finish is not about how much paint is applied but,how well its applied and then how well itsflat n polished.the more paint on there the deeper the chips will be when a stone hits it
you are missing the point. it's not a matter of wanting as much paint (or actually clear coat) as possible, but whether or not he did in fact give it the extra clear coat layer or not.
I have several points on the car where I know for a fact it only has the stock paint and that it will not have extra filler etc.
This thread was not to start a debate on paint job strategy, all I wanted to know was the stock paint thickness.
thanks for the inputs.
the stock paint won't be the same thickness all over the car anyway, hence why you get a paint depth gauge and check all the panels before detailing, if you haven't done that then you may have a tricky time, but Michael is pretty much on the money 130>150um
just because you've agreed on a number of coats,wont give an exact thinkness.
it depends on paint viscosity(thinkness it self)and no 2painters apply paint exactly the same,to gaurantee how many coats are applied you'd have to watch the paint going on
