magnos Posted August 8, 2008 Share Posted August 8, 2008 I bought this boost controller from a member of the forum and don't know what size that pipe is,can't find it in shops,it's the pipe that goes in the unit ,is a blitz sbc dual selenoid old spec only lo and hi any help..is verry welcome thanks Link to comment Share on other sites More sharing options...
jacko Posted August 8, 2008 Share Posted August 8, 2008 if you mean vacuum hose i imagine either a 6 or 4mm Link to comment Share on other sites More sharing options...
Nic Posted August 8, 2008 Share Posted August 8, 2008 If you measure where the pipe fits to I can probably supply what you need. As said it'll be either 4mm or 6mm Link to comment Share on other sites More sharing options...
kieren1234 Posted August 9, 2008 Share Posted August 9, 2008 With my Blitz DSBC i have a black pipe that actually goes inside the boost controller (have to open it up to attach. Is this the one you need as im sure its less that 4mm. Mine then has a pipe connector on the end and then has 4mm silicone piping. Link to comment Share on other sites More sharing options...
magnos Posted August 9, 2008 Author Share Posted August 9, 2008 ok thanks,how much would that cost me Nic?and when can I have it delivered thanks again does anyone has a fitting instruction picture or something thanks Link to comment Share on other sites More sharing options...
