Rubber sheet
ADL Mark
Bit obscure, I've found similar on eBay but only in big sheets and I don't need a big sheet..
Looking for a sheet of roughly 3mm thick rubber, need about 0.5m x 0.5m of it, preferably black, silver or white. Needs to be smooth, not ribbed (oo-er) or patterned.
Anybody? :search:
You not grown out of the bed wetting yet :D
My Mummy says I'm special :D
It's for using instead of a bearing between two pieces of metal, so instead of freely moving they are static. The 3mm is thicker than the bearing so the idea is to clamp the rubber down and it hold things together.
