L33 Posted July 23, 2008 Share Posted July 23, 2008 wil be raising the boost on my j spec soon but not sure which boost controller to go for. there is the cheap and simple greddy profec B one, or i seen there is loads of flash fancy ones with alsorts of displays and colour stuff. but is it needed? what does every one else use? any recommendations? cheers Link to comment Share on other sites More sharing options...
uk-rich Posted July 23, 2008 Share Posted July 23, 2008 i've just got a greddy profec b one on ryans recommendation, reasonable cost, does what you need it to Link to comment Share on other sites More sharing options...
GlennK Posted July 23, 2008 Share Posted July 23, 2008 Blitz DBSC R for a TT. Simple. Compact. Does the job nicely on my JSpec TT. Link to comment Share on other sites More sharing options...
suprattgaz Posted July 23, 2008 Share Posted July 23, 2008 Got the same, works just brill Link to comment Share on other sites More sharing options...
paul mac Posted July 23, 2008 Share Posted July 23, 2008 i have the profec B old style with no boost reading, very easy to set up, i also have the steering wheel mounted hi/lo boost switch which i have set at 1.2 bar from a standing start then 1.4 bar high boost when into second , it wont tell you your battery voltage, revs, throttle position or yesterdays cricket results, it just does exactly what it says on the tin............control boost Link to comment Share on other sites More sharing options...
uk-rich Posted July 23, 2008 Share Posted July 23, 2008 can you get the button for the newer profec b 2 ? Link to comment Share on other sites More sharing options...
uk-rich Posted July 23, 2008 Share Posted July 23, 2008 it seems they come with the kit Link to comment Share on other sites More sharing options...
paul mac Posted July 23, 2008 Share Posted July 23, 2008 can you get the button for the newer profec b 2 ? yes i'm pretty sure it does both, if you have the small jack connection on the back of the controller thats what its for Link to comment Share on other sites More sharing options...
flyby Posted July 23, 2008 Share Posted July 23, 2008 i have the profec B old style with no boost reading, very easy to set up, i also have the steering wheel mounted hi/lo boost switch which i have set at 1.2 bar from a standing start then 1.4 bar high boost when into second , it wont tell you your battery voltage, revs, throttle position or yesterdays cricket results, it just does exactly what it says on the tin............control boost hey how did you mont this? I can get mine to work.. Link to comment Share on other sites More sharing options...
Luxluc Posted July 24, 2008 Share Posted July 24, 2008 I have a Profec B spec II too ... like it a lot ... userfriendly and not too big. Link to comment Share on other sites More sharing options...
paul mac Posted July 24, 2008 Share Posted July 24, 2008 hey how did you mont this? I can get mine to work.. i have the reciever (the bit that plugs into the profec) behind the dash up near the speedometer, make sure your battery is good in the steering mounted switch Link to comment Share on other sites More sharing options...
