How to check what diff i have?
Franko
Guest CoolsBlue
Hmm i remember on my old supe, on the VIN plate, at the bottom, if there is a letter A you have a LSD diff and if its B you have a standard one, mine had the A irrc, or have i got it the wrong way round? (mines had a LSD) *waits to be corrected*
Exact opposite of what you just said. :p
in a fwd car..you can jack on side up, then see if you can turn the wheel off the ground, if it turns you have no lsd...if it doesnt you have an LSD...would be hard to do it in a supra that way as the handbrake would need to be off, and it jacked up at the same time, you dont want it to roll away.
From info picked up on other threads, you need to look for the A/B at the end of the Axle code. The A/B at the start has something to do with the size of the diff. The spread sheet link should sort it out for you anyway.
  • 4 weeks later...
