Obvious Markings? TRD Diff - to 6speed Diff
bolarbag
Just want to confirm, is there any markings on the TRD Diffs compared to the elements you are replacing?
i.e I have a j-spec 94 6spd, I have the diff casing with the big ears so to speak, I have a TRD Diff with the big ears so its the correct casing e.t.c, but is there no markings to differentiate?
If yours is an early model 6spd diff, then it will have either the standard factory fitted or aftermarket LSD inside as there was never an open diff used in this casing. As CW says to know which you have, you'd have to remove the rear cover.
Left is an early model 6spd TT diff, on the right is the diff used on all the other Supra models (including the facelift 6spd).
http://img210.imageshack.us/img210/2994/supravsoarerex8.jpg
View from opposite side
http://img177.imageshack.us/img177/5899/supravsoarer2ds2.jpg
