kosmic Posted June 28, 2008 Share Posted June 28, 2008 I currently have a HKS Hi-Power exhaust system and wanted to change to something that hasnt been done before. I came across the idea of quad tailpipes from the rear of the current Corvettes and think it looks really good, the only prohibiting factor maybe the fuel tank being in the way, the other idea was having the pipes come through the ab-flug type diffuser...F1 style I did a quick crude paint edit on the abflug supra for your thoughts, opinions and suggestions...? http://img501.imageshack.us/img501/9902/supraabflugot2.jpg http://img501.imageshack.us/img501/9902/supraabflugot2.8de7d61cd5.jpg Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 28, 2008 Share Posted June 28, 2008 I like it but I cant imagine it will be cheap to make because it will have to be a one off Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 28, 2008 Share Posted June 28, 2008 looks good on the abfug car.... But not a more normal supra Quote Link to comment Share on other sites More sharing options...
michel lane Posted June 28, 2008 Share Posted June 28, 2008 The fuel tank is in the way . The only is to put the fuel tank in the boot. Quote Link to comment Share on other sites More sharing options...
Daston Posted June 28, 2008 Share Posted June 28, 2008 would look good on an Abflug car but not on a stock one Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 28, 2008 Share Posted June 28, 2008 Twins look good but as said the fuel tank may be in the way. Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 28, 2008 Author Share Posted June 28, 2008 The fuel tank is in the way . The only is to put the fuel tank in the boot. yes, that being the main problem aside from custom fabrication, an ATL fuel cell would be the answer mounted in the car. Quote Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2008 Share Posted June 28, 2008 The fuel tank is in the way . The only is to put the fuel tank in the boot. Yep, and it's a PITA for my plans Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 28, 2008 Share Posted June 28, 2008 out the side like gt300, spit flames - kerb appeal Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 28, 2008 Author Share Posted June 28, 2008 Twins look good but as said the fuel tank may be in the way. http://i30.photobucket.com/albums/c338/jamie450x/twinpipe-1.jpg this would be slightly different in that the pipes are closer together and there is quad pipes like so: http://img386.imageshack.us/img386/4066/c1ep4.jpg http://img386.imageshack.us/img386/4066/c1ep4.72ab0cbb9c.jpg http://img517.imageshack.us/img517/8338/c2at2.jpg http://img517.imageshack.us/img517/8338/c2at2.c17bc2c953.jpg Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 28, 2008 Author Share Posted June 28, 2008 out the side like gt300, spit flames - kerb appeal Also scare the living cr@p outta pedestrians Quote Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2008 Share Posted June 28, 2008 out the side like gt300, spit flames - kerb appeal It's a no-go with the chassis on the Mkiv... already looked into that one Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 28, 2008 Share Posted June 28, 2008 how did top-secret do it? cut cut cut Quote Link to comment Share on other sites More sharing options...
Ewen Posted June 28, 2008 Share Posted June 28, 2008 Looks mean, but 6 into 4 dont go easy. Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 28, 2008 Author Share Posted June 28, 2008 On Some cars (Bmw E39 M5 & E46 M3) the rear back box is laid behind the fuel tank from left to right and then the exhaust pipes protrude from this, i think this system may be possible in the very small gap between the tank and rear bumper...similar to this: http://img46.imageshack.us/img46/4967/gruppeme46m3exhaustdpqg9.jpg Quote Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2008 Share Posted June 28, 2008 how did top-secret do it? cut cut cut They did it in the way you wouldn't use on a road car Getting a nice sound is one thing, cutting up the cars frame for it is a line most wouldn't want to cross Quote Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2008 Share Posted June 28, 2008 On Some cars (Bmw E39 M5 & E46 M3) the rear back box is laid behind the fuel tank from left to right and then the exhaust pipes protrude from this, i think this system may be possible in the very small gap between the tank and rear bumper...similar to this: No-go: fuel tank again Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 28, 2008 Share Posted June 28, 2008 Would you not be able to run square cut pipes out the back? Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 28, 2008 Author Share Posted June 28, 2008 No-go: fuel tank again What is the gap anyway, even maybe a 3" pipe laterally with 4 pipes sticking out? Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 28, 2008 Share Posted June 28, 2008 top secret do some funny things Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 28, 2008 Share Posted June 28, 2008 My mk3 had a side exit exhaust. Was OK in the UK but almost fried a dutch cyclist when it lit up the biggest exhaust fireball I have ever seen Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 28, 2008 Author Share Posted June 28, 2008 top secret do some funny things http://mkiv.com/mkiv_gallery/mkiv_gallery/exterior/large/jun09_39.jpg That must have had some serious cutting and grinding to get that to fit, quick paint sketch but something like this: http://img106.imageshack.us/img106/430/exhaustlh0.jpg http://img106.imageshack.us/img106/430/exhaustlh0.3868da61c9.jpg Quote Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2008 Share Posted June 28, 2008 Yes, you could do that, it's the only way without messing with the tank. It'd have a very poor flow and will not help the engine at all. It's a step too far for the sake of being different IMO. Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 28, 2008 Author Share Posted June 28, 2008 Yes, you could do that, it's the only way without messing with the tank. It'd have a very poor flow and will not help the engine at all. It's a step too far for the sake of being different IMO. I can see the sharpish angle being a restriction, will have a closer examination under the car tomorrow me thinks Quote Link to comment Share on other sites More sharing options...
gordy07 Posted June 28, 2008 Share Posted June 28, 2008 Thats a good idea but lots of hassle and exspense for a couple of extra tailpipes personally i think the money could be spent on other things(to do with the supe) Unless youve got money to burn(so to speak) Quote Link to comment Share on other sites More sharing options...
