how to: reset ECu/ stail fuel also
drnas78
Any ideas on resetting ECU
i understand its afuse that needs to be taken out any ideas or picture of which fuse it is, Also how long do i need to keep it out for .
Stail FUEL. any idead how this goes ive filled car up full tank do i need to do anything else
(prob is car not accelaretin well been told could be the above) again its a non turbo auto
02 sensors need replacing? Need to clean airfilter? Replace fuel filter - could be blocked? Spark plugs ok?, dizzy cap or rotor arm might need replacing, coil packs could be bad too. Personally I would change the lot, I did :) Also try a different fuel brand
I've looked at two of your threads now and both are bordering on illegible, can you please put some effort into what you type otherwise a lot of people who could help simply won't bother spending the time and effort needed to decipher what you are saying.
Thank you.
-Ian
Hi there,
I've put some fuel cleaner in and also reset the ECU, doesnt seem to have made much diffrence.
I think i will get a dignostic done instead of changeing loads of things best get the diagnostics done first.
