Tricky-Ricky Posted May 27, 2008 Share Posted May 27, 2008 Where can i get one, who sells them? Link to comment Share on other sites More sharing options...
Homer Posted May 27, 2008 Share Posted May 27, 2008 Chris Wilson, most parts place like thinkauto. Link to comment Share on other sites More sharing options...
n boost Posted May 28, 2008 Share Posted May 28, 2008 If your on about a bung to weld in your exhaust, i got a nut from my local spares shop and welded that in and used a bolt to block it as i could not wait for delivery. Just as good as any bung if u ask me. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 28, 2008 Author Share Posted May 28, 2008 Thanks guys, unfortunately there is only one nut & bolt supplier around here and there pretty useless, i just need the bolt to block it off. Link to comment Share on other sites More sharing options...
bignum Posted May 28, 2008 Share Posted May 28, 2008 I`ll see if i can find mine. Link to comment Share on other sites More sharing options...
ADL Mark Posted May 28, 2008 Share Posted May 28, 2008 Dick, let me check in the shed. I'm pretty sure I got a spare one with the Innovate, or the one that came out of my downpipe. Will see what I can find Link to comment Share on other sites More sharing options...
steb9780 Posted May 28, 2008 Share Posted May 28, 2008 I think they are M18 x 1.5mm pitch, if you are going to buy a nut. Link to comment Share on other sites More sharing options...
bolarbag Posted May 28, 2008 Share Posted May 28, 2008 Thanks guys, unfortunately there is only one nut & bolt supplier around here and there pretty useless, i just need the bolt to block it off. Can I ask why your not using a lambda sensor or do you have another one fitted already? Just curious;) Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 28, 2008 Author Share Posted May 28, 2008 Thanks bignum, and Mark, the reason i need one is because there are three lambda bosses in the down pipe i have, one std and two wideband type, and my sensor is already in the second decat, where its staying for the time being, and i only had one bung. Link to comment Share on other sites More sharing options...
