Jake Posted February 15, 2005 Share Posted February 15, 2005 I've got a second hand Thor FCD (or VFCC if you prefer) from a non-VVTi pre-facelift Supra and I want to install it in my '98 VVTi Tiptronic RZ-S but I don't have the VVTi instructions. All the links to the Thor/TRL diagrams in old threads are now dead. It would be a bit of cheek to ring Pete up for these, can anyone help me out with a FCD wiring diagram and a VVTi ECU pinout diagram? Thanks Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2005 Share Posted February 15, 2005 Send me your fax number and I can fax you a hard copy. Quote Link to comment Share on other sites More sharing options...
Jake Posted February 15, 2005 Author Share Posted February 15, 2005 Thanks Chris but I haven't got a fax. I'm at home. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted February 15, 2005 Share Posted February 15, 2005 you can fax it me at home and i can take a digital pic of it for you Jake (will check whether dad has left digital camera at home.) or is the quality gonna be too poor after that? Quote Link to comment Share on other sites More sharing options...
Jake Posted February 15, 2005 Author Share Posted February 15, 2005 Thanks WSB but I found this in an earlier thread : So I guess I need to connect the FCD into the cut MAF wire, right? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2005 Share Posted February 15, 2005 WARNING!!! There was a TRL diagram doing the rounds with the WRONG pinouts shown, and I think this is it! I am sure you will find the MAP sensor wire is where the MAP pin is shown on the daiagram! The correct MAP wire is yellow and black, that's the one you need to cut and the green from the TRL device goes to the ecu side of the cut wire, and the blue goes to the MAP sensore side (engine side). Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2005 Share Posted February 15, 2005 TYPO now, reverse the leads from the TRL device, blue to the ecu side, green to the sensor side, sorry, rushing.... Quote Link to comment Share on other sites More sharing options...
Jake Posted February 15, 2005 Author Share Posted February 15, 2005 Blimey! Thanks Chris. I have managed to get a TRL ECU pinout diagram thanks to Geoff Valenti (Thanks Geoff) I'll make sure to check it's the Black and Yellow wire I'm cutting! Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 15, 2005 Share Posted February 15, 2005 That diagram is correct, pin 14 on block B is the MAF airflow signal (red-blue), and pin 15 on block B is the MAP signal (black-yellow). All the other connections are correct as well, although you could use block E pin 16 (bottom left of last block on diagram) as the ground, it's the beefy ECU ground wire (white-black) and it's easier to get at. -Ian Quote Link to comment Share on other sites More sharing options...
Jake Posted February 15, 2005 Author Share Posted February 15, 2005 Cheers for that Ian. I was going to use the nut that holds the ECU down as an earth anyway. Doing that solved my 'faulty' SLD problem in the past. Quote Link to comment Share on other sites More sharing options...
halllon Posted April 7, 2008 Share Posted April 7, 2008 So I guess I need to connect the FCD into the cut MAF wire, right? Is this correct? I thought it should be spliced into the cut MAP wire rather than the MAF wire :S Quote Link to comment Share on other sites More sharing options...
