benkei Posted May 26, 2008 Share Posted May 26, 2008 Are there any visual differences between a pre-facelift and a facelift? Like slightly modified bumper design, different headlights, tail lights, indicators, etc. I know most of the mechanical differences, like VVTi and bigger brakes and wheels... It's just on the outside I can't tell? Pics if possible!! Link to comment Share on other sites More sharing options...
juanchan Posted May 26, 2008 Share Posted May 26, 2008 Sidelights moved to the indicator pod in the bumper, side repeater moved from front wing to the front bumper, side repeater added just forward of the rear bumper, rear light surround is gray instead of black, dash has 3 small dials on the right instead of the large fuel and temp gauges... I'm sure there's others! Link to comment Share on other sites More sharing options...
Ric Posted May 26, 2008 Share Posted May 26, 2008 diffrent lights front rear and side and the facelift bumper on the front has a line through the mouth Link to comment Share on other sites More sharing options...
Guest ulysses31 Posted May 26, 2008 Share Posted May 26, 2008 changes also include the front bumper, and size/placement of indicators and side repeaters. Not sure but the bonnet scoop and headlight washer thingys may also be a facelift change..... dont quote me on that one though. check google or some peoples garages on here. Link to comment Share on other sites More sharing options...
miko_supra Posted May 26, 2008 Share Posted May 26, 2008 Black headlights Grey rear lights Different wheels Splitter in the middle of the front bumper Reflectors on the sides of both front and rear bumpers Clear front indicators Link to comment Share on other sites More sharing options...
Tee from China Posted May 26, 2008 Share Posted May 26, 2008 OK, here are some pictures for your edification:eyebrows: Black one is Pre-facelift and the White is ...err Facelift! Link to comment Share on other sites More sharing options...
Jake Posted May 26, 2008 Share Posted May 26, 2008 I know most of the mechanical differences, like VVTi and bigger brakes and wheels Bigger brakes is not a facelift or VVTi thing. I've had a VVTi with the smaller 2pot front brakes. Not sure but the bonnet scoop and headlight washer thingys may also be a facelift change..... dont quote me on that one though. Actually, neither of those things are found on facelift Supras. They were standard issue on UK specs though (which were pre-facelift of course) Link to comment Share on other sites More sharing options...
jaymdee Posted May 26, 2008 Share Posted May 26, 2008 As Jake says, bigger brakes and wheels and VVTi are also on non facelift, so I'm afraid you're incorrect there. from what I've seen, Facelifts have front and rear indicators integrated into the bumpers, have different head lights and some also have little lights in the rear spats and reflectors inside the doors Link to comment Share on other sites More sharing options...
Jake Posted May 27, 2008 Share Posted May 27, 2008 As Jake says, bigger brakes and wheels and VVTi are also on non facelift, so I'm afraid you're incorrect there. No mate, that's not what I said. What I meant was that facelift or VVTi Supras do not necessarily come with the larger brakes (Some facelifts have them, some don't) Also, to correct you on another thing, all VVTi Supras are facelift ones - but not all facelifts are VVTi because VVTi came out after the facelift changes were introduced. Link to comment Share on other sites More sharing options...
benkei Posted May 27, 2008 Author Share Posted May 27, 2008 I've seen there's a lot of confusion with Supras as they have so many additional options to be added, and the facelifting doesn't seem to be at a set point, more of a gradual thing! The pictures really helped Tee, thanks! Are there slight changes to the rear spoiler too? I've seen some with more 'pointy' spoilers where others are more rounded at the back... Link to comment Share on other sites More sharing options...
Nic Posted May 27, 2008 Share Posted May 27, 2008 I've seen there's a lot of confusion with Supras as they have so many additional options to be added, and the facelifting doesn't seem to be at a set point, more of a gradual thing! The pictures really helped Tee, thanks! Are there slight changes to the rear spoiler too? I've seen some with more 'pointy' spoilers where others are more rounded at the back... The facelift Supra was launched May 1996, the 2JZGTE VVTi engine was launched September 1997. So as Jakes said the first facelift TT Supras had the non-VVTi engine between that period. No change to the rear wing, are you thinking of the TRD rear wing? Pics here: http://mkivsupra.net/vbb/showthread.php?t=98103 Link to comment Share on other sites More sharing options...
benkei Posted May 30, 2008 Author Share Posted May 30, 2008 (edited) Nah mate, it's no the TRD spoiler, it looks like the OE spoiler, just more pointy... if that makes sense? Edit: I just found the picture again, and the spoilers are the same, just the angle the picture is at makes them look different! Edited May 30, 2008 by benkei (see edit history) Link to comment Share on other sites More sharing options...
