drnas78 Posted April 5, 2008 Share Posted April 5, 2008 Hi Hello hope ur all well Peeps my cars lost power and i can feel it, I no its a Non turbo auto but when i used to put my foot down I could feel car move and a knock back into the drivers seat but now doenst feel at all the same seems noise high but acceelrations not theres very slow response to accelarations,and no knock back Any suggestions ideas, Has been parked for while was serviced few months before parking up. Please help Link to comment Share on other sites More sharing options...
edge Posted April 5, 2008 Share Posted April 5, 2008 Check the plugs, leads and distributor cap and arm firstly even if it was serviced. Does it seem like a missfire is happening at all? Link to comment Share on other sites More sharing options...
drnas78 Posted April 5, 2008 Author Share Posted April 5, 2008 There doesnt seem to be any miss fire starts first time doesnt clunk of (auto) while driving or at lights etc just feels powerless when puting ur foot down seems to really struggle Link to comment Share on other sites More sharing options...
Nic Posted April 5, 2008 Share Posted April 5, 2008 How long was it stood for? Are you using the petrol that was sat in the tank whilst it was stood? Link to comment Share on other sites More sharing options...
drnas78 Posted April 5, 2008 Author Share Posted April 5, 2008 Hi nic hope ur well pal it was sat for about 8-9 mnths, the light was on possibly a bit of use with light on just hoping to find out what could be wrng and how to sort it Link to comment Share on other sites More sharing options...
Andy Blyth Posted April 5, 2008 Share Posted April 5, 2008 I've had a similar problem with a previous car. It turned out to be a siezed piston in the brake caliper. Might be worth checking out. Link to comment Share on other sites More sharing options...
drnas78 Posted April 5, 2008 Author Share Posted April 5, 2008 im not the best techi whats a pison (do you mean piston) if not were can this be found Link to comment Share on other sites More sharing options...
Nic Posted April 5, 2008 Share Posted April 5, 2008 im not the best techi whats a pison (do you mean piston) if not were can this be found The piston inside the brake caliper. It is a good suggestion, it could be the brakes that are binding on the disc. Did you leave the car stood with the hand brake on? If you did then it could be the brake shoes are binding on too. Link to comment Share on other sites More sharing options...
drnas78 Posted April 5, 2008 Author Share Posted April 5, 2008 ok ill get that checked theres no noise out the brakes at all squeeking or grinding however Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 5, 2008 Share Posted April 5, 2008 i had i similar thing the other day or maybe it was just me, i havint really give the car a good go as yet havint had it long, its an import TT, came off a roundie on to some straight round and started pressing the throttle down not hard but just to increase the speed, felt slow, then pushed throttle right diwn to floor and still nothing, few miles up the road and gave the throttle the smallest of pokes and woof i was off second in pinned in seat, strange that, i been reading on here about the vsvs can play up, cars dun 79,000miles, any advise Link to comment Share on other sites More sharing options...
Andy Blyth Posted April 5, 2008 Share Posted April 5, 2008 im not the best techi whats a pison (do you mean piston) if not were can this be found Oops! Yeah, I meant piston. For pictures of them, see this thread. I guess the easiest way to see if this is the problem is to go for a short drive (a few miles maybe) without using the brakes too much. When you come to a stop, go round to each wheel and try and judge the temperature of the brakes. (be careful not to burn yourself!) Often, just getting your hand close to the brake disk will be enough. If one of the brakes is significantly hotter than the others, it could be pointing to a siezed piston. Link to comment Share on other sites More sharing options...
drnas78 Posted April 5, 2008 Author Share Posted April 5, 2008 will do that also will do what nick says tank it up and se ehow it goes and get brakes checked or pistons in brakes checked lets hope its nothing more then taht i that it could be some sort of gear box sensor or something like that Link to comment Share on other sites More sharing options...
drnas78 Posted June 2, 2008 Author Share Posted June 2, 2008 Hi there Just a bit of an update, tanked her up fully twice now no ral diffrence, Checked gear box oil it is brown and not normal redish colour. I'm worried now that car's Gear box/ Torque Converetr may be on itsits way out or already has gone. Link to comment Share on other sites More sharing options...
