ACL Bearing Kit for rebuild
_Shane_
 Share
My engine was rebuild by "Merseyside engine parts & repair specialist."
"removed engine+strip, Crankshaft work, supply + fit new crankshaft, conrond bearrings. Hone bores + re-rings piston, replacment skim tappats to cylinder head. ..."
ACL 0.25 oversize
Price £1500 5/4/06
I talk to a local tuner here, he also say ACL is a very good product.
I asume I was wrong then.
When thay rebuild the engine thay did not change olie pump!
And both my turboes is damaged too, and i have a lot of oile in the airvent and intercooler (from turboes)
http://www.mkivsupra.net/vbb/showthread.php?t=147796
Thats quite cheap for a rebuild... When mine had just the head rebuilt it cost over 2.5k
holy crap mate, you do realise you can get a brand new "bare" head from the states for about £600 and titanium valves for about £350, i hope you have something special in there for 2.5k :blink:
  • 2 weeks later...
Do i need to change all bolts to new when fitting new CON and MAIN bearings ?
Not necessarily. The bolts stretch when tightened - the tech manual gives minimum thickness of the bolts - you measure them at the thinest point and can re-use if they meet the specs.
However, if you're going to the trouble of tearing down the block you may as well replace them.
Quite right, there are something like 7 standard main bearing sizes and 3 rod bearing sizes. There's no such thing as a standard size bearing.
I was a my toyota dealer. He confirmed that there is 6 size og main bearings. No such thing as a standard size bearing.
So I replace my whit toyota and not ACl standard size...
What you need to do really is measure your crank journal sizes and bearing cap bore (although that should be the same as the number stamped on the block) and then find the size of the bearings and see what the clearance would be. I've actually decided to go with ACL bearings now as when I did this I found the clearances would all be fine.
For reference the sizes that ACL make three different size ranges, STD, 0.25 and .25 oversize (the latter two are for reground cranks). For the STD ones they do a standard clearance version (the H) and a +0.001" clearance version (the HX). For the STD size ones the sizes are:
con rods H=1.506mm HX=1.493mm
mains H=2.004mm HX=1.991mm
The H mains correspond to size 4 standard bearings and the con rod H ones are size 2 standard ones.
Edited by SimonB (see edit history)
For mi engine i need Main: 3pce "3" and 3 pce "4" and one "4" big end.
All my conrod is size 2.
Does ACL not only sale a set of "3" and a set of "4" ?
I think you might find that your clearance would still be easily in spec using ACL bearings then, the difference between 3 and 4 is very small indeed.
after measuring my crank with a mic from work i chuckled to myself on the differences in the main bearing journals and after listening to the venerable old sage Wilson i to have decided to go with ACL (standard size) bearings
ACL bearings are fine. Toyota engines were designed with even wear in mind and so the bearing size structure was formed to put all clearances bang on and true in the hope they would wear evenly and the engine last longer as a result, as we all know toyota engines last forever. This being said i can tell you its all a load of tosh :D in every engine I have opened the bearings furthest from the pump wear first.
I build with ACL and Clevite bearings which once fitted to a stock unmodified crank and rod always measure within tolerance.
Hope that helps.
James
Just use ACL or any decent bearing and use plastigauge. as a double check, the tolerances on the gradings are so minute as to be ignorable.
sorry Chris i called you the venerable old sage Wilson would venerable sage Wilson be more acceptable :D
 Share
