Scoboblio Posted January 28, 2005 Share Posted January 28, 2005 Hi people..... When I get up to about 120mph+ I get quite a severe vibration through the wheel / dash etc. I've been informed by a tyre place that it wouldn't be the wheel balancing, so in your opinion am I looking at a warped / damaged wheel? The car had brand-new alloys + tyres on it when I bought it but because of the limiter I couldn't take it above 112mph until recently so didn't notice. If it is a damaged wheel is it something I can easily test for? Link to comment Share on other sites More sharing options...
tbourner Posted January 28, 2005 Share Posted January 28, 2005 Mine does that too, at exactly 120 almost, I am also feeling a wobble at 30 and 70 as well. I've had a few people tell me that my rear wheel is buckled/wobbling, and now that rear shock is on it's way out. So it could be the same thing. I'm now looking for cheap alloys and cheap shocks. Link to comment Share on other sites More sharing options...
Nic Posted January 28, 2005 Share Posted January 28, 2005 Could be a number of things, wheel balance, wheel bearings, worn bushes, shocks, tracking etc. Best to get it on a ramp and get some one to give a good going over. See my thread in the tech section, number of things found on minetoday to sort out. Link to comment Share on other sites More sharing options...
Scoboblio Posted January 28, 2005 Author Share Posted January 28, 2005 Thanks, got some time off work coming up so I think I'll take it in for a good going over Link to comment Share on other sites More sharing options...
Steve W2 Posted January 28, 2005 Share Posted January 28, 2005 Your new tyres and alloys, are they different size to what was previously fitted? Do you have uprated suspension as well? If so you may also need to have the camber adjsuted. I wouldn't rule out tracking/balancing either just because one mechanic said so. Link to comment Share on other sites More sharing options...
gav Posted January 28, 2005 Share Posted January 28, 2005 I had similar problem (vibration at about 90MPH). Got new Good Year Eagle F1 Tyres fitted and was told by the monkeys at Tyre Spot I needed spiggott rings fitted behind my front volkracing alloys to correct the vibration. Since fitting these £5 each, there has been no vibration at all. Link to comment Share on other sites More sharing options...
_Rob_ Posted October 2, 2006 Share Posted October 2, 2006 Did you ever find out what this was Scobolio? More or less 120 dead and upwards.. Link to comment Share on other sites More sharing options...
jazz1 Posted October 2, 2006 Share Posted October 2, 2006 how do you know the wheel bearings are gone? Link to comment Share on other sites More sharing options...
Ulrik Posted October 2, 2006 Share Posted October 2, 2006 Best and cheapest way is borrow some wheels/tires from a friend, and run the car again, and check for vibration... So you dont buy stuff when u dont need them... Try the cheapest / easyest things first Link to comment Share on other sites More sharing options...
Nic Posted October 2, 2006 Share Posted October 2, 2006 how do you know the wheel bearings are gone? Jack the car up and check for any side to side play of the wheel. If there is any movement of the wheel, the bearing needs replacing. Link to comment Share on other sites More sharing options...
