no error codes and warning light on.
supra steve
my red warning light is on,checked the diagnostics and has no errors.the only thing i can think of is that i removed my active spoiler and my aircon while fitting my fmic.can anyone tell me what could be wrong and also how to get rid of the flashing light on the active spoiler?thanks.
I presume the light comes on at a certain speed? If it does then it'll be the warning light for the active spoiler. Turning the spoiler button to off should stop the warning light.
It will stay on until you remove the active spoiler ECU. To do that, go behind the centre dash console panel, and underneath the CD cage area there will be a smallish yellow ecu box. disconnect that and your warning light will turn off
:yeahthat:
Both my J-Spec and Uk Spec had the red triangle on and they both did not have the active spoiler. Red light went off both times when the ECU was taken out.
