question ---
Guest ravi
I think I am right in saying that you will struggle to fit 20's without some arch work (rolling or shaving). Also there is a respected opinion that the handling of the car will suffer greatly, and your tyre wear will be seriouslt uneven.
I'm sure there will be some posts that dispute these "facts"
Mike
However if you decide you still want the Tyres - according to the Plus One Concept (see here) search for Plus One.
You should be looking at about 305/15/20s rear and 275/20/20s front. Which sound ludicrously expensive, if available at all. I'm not sure I agree with the concept personally, but the rest of the guide is very good.
Remember you need to retain the same rolling radius to keep the speedo accurate.
edit: having said all that you could probably use 275/25/20s on the rear.
Mike
