Epic Posted February 3, 2008 Share Posted February 3, 2008 Right, i want to odo a full service on the car... im sure its alot cheaper to do it my self so making a shopping list. This is what i have so far... oil filter - Stock fuel filter - Stock air filter - Stock spark plugs - NGK BCPR7ES engine oil change - 5w50 Fully Synthetic 6L's Diff oil - 75w90 - Motul Gear 300 or Silkolene Syn5 2L's Flush cooling system - Toyota 4Life Red 9L Gear Box oil - Toyota Type-IV 2L's Power steering fluid - Dexron III 4L's Brake Fluid - DOT 5.1 1.5L's Belt last changed 20k miles ago Do i need anything else? any suggestions on oil and sparks? i might as well get BPU Sparks right? Its for my UK TT, 126k miles stock Link to comment Share on other sites More sharing options...
JustGav Posted February 3, 2008 Share Posted February 3, 2008 Unless you have changed the coolant since you have owned it, I would suggest refreshing it and flushing the cooling system through, that way you know that is good as well. I'd even suggest considering diff oil as it isn't a difficult job either. Link to comment Share on other sites More sharing options...
Epic Posted February 3, 2008 Author Share Posted February 3, 2008 added, any more suggestions? thanks very much. also any clue what oil for the diff? Link to comment Share on other sites More sharing options...
Al Massey Posted February 3, 2008 Share Posted February 3, 2008 have a search for opie oils, there was a great thread on all oils and lubricants to use on the supra Link to comment Share on other sites More sharing options...
Pixelfill Posted February 3, 2008 Share Posted February 3, 2008 gearbox oil For autos this would be Toyota Type IV. for manuals I don't know as the recommended oil has been discontinued. power steering fluid - Dexron III brake pads, and fluid timing belt and aux belt ? if you don't know when/if they've been done. Mike Link to comment Share on other sites More sharing options...
Epic Posted February 3, 2008 Author Share Posted February 3, 2008 updated Link to comment Share on other sites More sharing options...
Epic Posted February 3, 2008 Author Share Posted February 3, 2008 Does my list now look correct guys? if so i best get buying. im sure it aint going to be cheap Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted February 3, 2008 Share Posted February 3, 2008 You'll need more than 2l of engine oil mate:) Link to comment Share on other sites More sharing options...
Pixelfill Posted February 3, 2008 Share Posted February 3, 2008 You'll need more than 2l of engine oil mate:) yup closer to 6L I use just over 5L on an oil change. and make sure its fully Synthetic. Mike Link to comment Share on other sites More sharing options...
Epic Posted February 3, 2008 Author Share Posted February 3, 2008 Synthetic, fully Synthetic or semi? Link to comment Share on other sites More sharing options...
snake Posted February 3, 2008 Share Posted February 3, 2008 If your gearbox is an auto it will only take two litres of type iv unless you want to flush and renew all the fluid in the box .It cost me about £16 for 4 litres from mr t.If you change the power steering fluid ,there is a very good write up on how to do it in FAQ section. I use fully synthetic oil for the engine Link to comment Share on other sites More sharing options...
Pixelfill Posted February 3, 2008 Share Posted February 3, 2008 If your gearbox is an auto it will only take two litres of type iv unless you want to flush and renew all the fluid in the box .It cost me about £16 for 4 litres from mr t.If you change the power steering fluid ,there is a very good write up on how to do it in FAQ section. I use fully synthetic oil for the engine Frak me ! I just bought a 5 litre bottle of Type IV from Toyota and paid just shy of £40 Mike Link to comment Share on other sites More sharing options...
snake Posted February 3, 2008 Share Posted February 3, 2008 Bought mine in a 4 litre tin a [while ago] i thought it was cheap at the time. Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted February 3, 2008 Share Posted February 3, 2008 I bought 4l from Steve Manley last year and that was £27:50. I thought that was a good price, but £16!! Where was that from? Link to comment Share on other sites More sharing options...
snake Posted February 3, 2008 Share Posted February 3, 2008 Mr Toyota in bristol . Link to comment Share on other sites More sharing options...
Epic Posted February 3, 2008 Author Share Posted February 3, 2008 Updated, looking like a good service guide for me to work from now. will have to get in contact with mr.T about prices maybe. should i just get the air, oil and fuel filter from my local parts place or shall i seek people on the forum for a better price? Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted February 3, 2008 Share Posted February 3, 2008 Updated, looking like a good service guide for me to work from now. will have to get in contact with mr.T about prices maybe. should i just get the air, oil and fuel filter from my local parts place or shall i seek people on the forum for a better price? Oil filter from your local parts place (unless you want more of a posh named one). Fuel filter from Toyota, £30ish. Air filter, not sure as mine's not stock. Link to comment Share on other sites More sharing options...
adam bell Posted February 3, 2008 Share Posted February 3, 2008 how do you change the power steering fluid Link to comment Share on other sites More sharing options...
snake Posted February 3, 2008 Share Posted February 3, 2008 GO TO FAQ /GUIDES . then select oil, fluid, interval etc . when you get to power steering section it will show you there . did mine yesterday . Link to comment Share on other sites More sharing options...
