Does any one know about down pipes for the supra mkiv tt?
Robbie
 Share
hello,
Ive got a uk soop, auto with hks intercooler, fuel pump, fcd, evc4, hks superdragger2, hks induction kit and stage 2 hybrids from turbo technics.
The second cat has been removed with the superdragger pipes but I would like to know if its a good idea to remove the front pipe?. Ive heard that by removing the front cat it can produce boost spikes and hard to control boost creep. Is it worth while buying an upgraded frnt catback pipe or somthing>>>or are the gains not worth bothering about.
AFAIK the power gain from the first cat removsal on the UK car are not as significant as a Jap spec due to the UK EGR system.
To get the real benefit you need a boost controller to develop the extra boost, that just happens on the Jap spec.
However you will get some power gain and reduce your EGTs as well, which is always a good thing. Dont forget the change in exhaust note/volume too.
Chris W will sort you out with the correct pipe for your UK car.
You won't have boost spike problems on a UK model. The removal of both cats will help the engine run cooler internally and remove heat from the engine ba. It will also spool somewhat faster and have better mid and top end power. Slightly more noise, nothing at all excessive though. Straightforward bolt in fitment. I have stock.... Contact details in my sig below. Cheers.
 Share
