HKS SLD - Damn english manual
Lebsteif
 Share
It is the light blue wire that is the odd one, the others should be connected like this.
Yellow - Speed sensor wire to ECU
White - Speed Sensor wire to loom
Black - Earth
Red - 12V ignition feed
Perhaps try connecting these 4 wires first and then test to see if works.
I'm waiting on a type t6 SLD coming in for an Aristo 2jzgte as they have a problem with the TRAC system, i know one of the wires on it is destined for the Trac ECU. Maybe the type 1 had that option? if i find out any details il post them up.
Ah that could be a reason!
Black - Earth
Thanks Nic, i;m going to give it a go. we will see what happens :D
Guest biglipzit
So what about the wiring for the HKS SLD Type 2?
Just got one and it has 12 wires. Don't have a clue as to what each one does.
Any help?
I have searched the forums and not one person has posted any wiring information for the HKS SLD type 2.
If i only use the 4 wires will it work? or are things different on an automatic mkiv?
  • 2 years later...
 Share
