car struggles to start
stevie_b
 Share
I know there are loads of threads on this topic, but I have a specific question about my car, which I haven't been able to find an answer to:
Quite often, when I go to start my car in the morning, I turn the key, and just get a single "click" from the engine bay, no cranking at all. All the dash lights light up fine. All the headlights, radio and other unnecessary peripherals are off. Wait 2 seconds, try again: single "click" with no cranking at all. Wait 2 seconds, try again: single "click" with no cranking at all. Wait 3 or 4 seconds, try again: strong cranking, and engine fires up fine.
I'm sure this is either the battery or starter motor. With the common starter motor fault, is it as tempramental as this? Same with the battery: can battery faults cause this type of tempramental problem?
I've got instructions on how to overhaul the starter motor, but I don't have the kit to do it (jack, axle stands, etc). I don't want to buy it and overhaul the starter if it's unlikely to be the cause of the problem. Likewise buying a new battery and finding out it's not the cause.
Any advice is appreciated.
Look here at what i found...
http://www.mkivsupra.net/vbb/showthread.php?t=77838
I had exactly same problem mate,a click or two leave for a second then fires up normally-very tempremental that progressively got worse!
Fixed for £15!!!!!!!!!And at home by using the risky method of driving up onto some bricks!im not large so could just about get under the car lol.
Went the hard way though by changing battery first before finding it WAS the starter.!
The parts you need are
28226-74070
28226-22050
Toyota dealership should be able to use those numbers for you and shold cost no more than around £15 (my bill was £15.20 all in)
  • 3 weeks later...
 Share
