Guru Posted June 14, 2006 Share Posted June 14, 2006 I really need some advice on this. My clock, heater and blower controls are still dead! I have checked fuses in the engine and cabin locations. The radio fuse did blow but I cannot find another dead one. Can anyone suggest which fuse to check or what the problem could be other than this? Quote Link to comment Share on other sites More sharing options...
Guru Posted June 15, 2006 Author Share Posted June 15, 2006 Anyone??? Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 15, 2006 Share Posted June 15, 2006 I sure you have checked but, have you had the dash off recently? Quote Link to comment Share on other sites More sharing options...
Guru Posted June 15, 2006 Author Share Posted June 15, 2006 Yep and everything was ok Quote Link to comment Share on other sites More sharing options...
Animal Posted June 15, 2006 Share Posted June 15, 2006 I had this happen to me last year and it turned out to be the cigarette lighter fuse that had blown. Took out the entire centre console. Replaced that and everything came back on. Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 15, 2006 Share Posted June 15, 2006 Not been playing around in the poassenger footwell area have you? Up by the large panel of connectors? Quote Link to comment Share on other sites More sharing options...
Guru Posted June 16, 2006 Author Share Posted June 16, 2006 No I didn't do anything I think that should have caused the problem Ben I will check the fuse for the lighter tomorrow Animal and the rest of the panel come to think of it. It's just sods law that the weather is soooooo hot when I have no air or AC..... Quote Link to comment Share on other sites More sharing options...
Guru Posted June 19, 2006 Author Share Posted June 19, 2006 Ok well dial illumination is now added to the list of things not working! I took the dash off and everything was perfect behind......WTF could it be! Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 19, 2006 Share Posted June 19, 2006 My heater stopped working when I inadvertently (SP) disconnected a connection in the passenger footwell. It was only a three wired connector but it fecked me up for a few days figuring it all out. Other than that, I'd check out all the fuses in the engine bay and in the drivers footwell just to be sure. Quote Link to comment Share on other sites More sharing options...
Stevie Boy Posted June 23, 2006 Share Posted June 23, 2006 I had similar fault after fitting a new stereo a couple years back and indeed was cigar lighter fuse in drivers footwell fuse panel! Had me confused as to the relationship between lighter, heater controls blower and clock but it was the culprit. Think may have shorted out the cigar lighter semi-exposed terminals on stereo cage when refitting facia panel. Was a sweltering hot day to loose A/C controls on too! Quote Link to comment Share on other sites More sharing options...
Guru Posted June 24, 2006 Author Share Posted June 24, 2006 Took EVERY fuse out and guess what.......cig lighter fuse blown! Arrrrrggggghhhhhhh! I blame smokers cos without them I would have been sweating less this past 2 weeks Quote Link to comment Share on other sites More sharing options...
S7EVE Posted June 24, 2006 Share Posted June 24, 2006 Had exactly the same problem last week!! Checked relevant fuses and guess what Cig lighter fuse gone! All sorted now. Glad its sorted matt. Quote Link to comment Share on other sites More sharing options...
baz78 Posted January 24, 2007 Share Posted January 24, 2007 Bump Help guys i have the same prob !! all my fuses are fine, My wires are all plugged in , Just my heater will not light up or work !!! clocks dash light etc are all fine , What can it be?? Need help Asap Quote Link to comment Share on other sites More sharing options...
Guru Posted January 25, 2007 Author Share Posted January 25, 2007 Did you specifically check the cig lighter fuse in the drivers box? Quote Link to comment Share on other sites More sharing options...
baz78 Posted January 29, 2007 Share Posted January 29, 2007 Yes mate i did , i found out my heater control box(yellow box) which sits on the stereo cage was missing , i have installed this but still no heater , make things worse no clock either . . There is still one more plug sitting behinde the dash is there another box missing? Quote Link to comment Share on other sites More sharing options...
Guru Posted January 29, 2007 Author Share Posted January 29, 2007 One is climate control (yellow) and the other is electric aerial (brown) Quote Link to comment Share on other sites More sharing options...
