Sard analyse ECU
Jellybean
 Share
Just seen I have a SARD Analyse ECU, anybody come across them or have any info?
http://file047a.bebo.com/13/large/2009/07/25/17/20295479a11296680800l.jpg
Can only find this
http://takakaira.com/Main.aspx
Analyse
Analyse is an ECU set to provide alteration of high boost & rev control at high speed driving, and provides accurate engine control in various conditions, such as partial range, street driving, and engine idling.
Resetting items of Analyse:
Fuel map resetting.
Ignition map resetting.
Rev limiter resetting.
Speed limiter cancellation.
Boost limiter cancellation.
It's strongly required to use high-octane gasoline after the replacement of ECU (in Japan "high-octane gasoline" values is 100~101%.
I had this on mu supe when it was BPU and came over from japan.
U can't get the software to map it but it ran well with good afrs on 1.2 bar boost(stock turbos) on v power.
Had a silly 8300 rpm rev limit but seemed to have 2 different maps on it.
When it was cold it felt like power was reduced and soon as it gets up to temp the throttle used to get alot more responsive.
I think u can also get SARD chips which are called analyser and are available for different boost levels.
U probably better getting something that can be mapped easily.
 Share
