1993 gt358466r
tonyhawk
 Share
Ok, it has come to this and the beastie has to go :(
It had a complete re-spray six months ago, engine rebiuld 3k ago and the valve guides a few days ago. The the main spec list is below, but what is not in the list is the Toad alarm with total closure and tracker unit.
I'm sure there are lots of things I haven't remembered, but I'm happy to answer any and all questions :)
I'm looking for £14k.
In the spirit of complete honesty, there are a couple of things that are not 100%: the wheels are not perfect and two of them have some surface corrosion that needs treating; the only other defect is on the bonnet, which has two cracks at the front; I wanted to get them sorted, but I haven't been able to find a good body shop that can work with CF. To get both issues sorted would probably be about about £500ish, which is why it's not priced as high.
Piccy's attached.
Spec:
Block:
JE Pistons
Bottom end lightened & balanced
ARP Stud bolts
ARP Rod bolts
PHR Oil pump
Cylinder Head:
Polished/Ported/Gas Flowed
Crower titanium valve springs & retainers
HKS Inlet and Exhaust Cams (264 degrees)
HKS Cam Wheels
New valve guides
Turbocharger, Induction & Cooling:
Garrett GT358466R (not the GT35R, this has a bigger induction impeller)
Boostlogic oil kit
HKS Wastegate with screamer pipe
Apexi Induction Kit
HDi Intercooler
HKS Dump valve
ASI rad
Fuel, Tuning & ECU:
AEM EMS with 3.5 Map & Boost solenoid
HKS DLI
SARD 800cc Injectors
SARD FPR
FPD Bypass
NGK BKR8 Plugs
Bosch 044 fuel pump
Exhaust:
Reworked, re-welded and ported XS Power manifold
XS Power downpipe
XS Power midpipe
HKS Superdragger rear box
Drivetrain:
RPS Flywheel
RPS Street clutch
Suspension, Wheels, Tires & Brakes:
BBS 18" rims
Yokohama AVS Sports (245 Front, 275 Rear)
Engine Dress:
Shiny Inlet Manifold
Shiny Plenum Chamber
Shiny Water pipe
Shiny Fuse Box Cover
Greddy Alloy pulley set
Greddy top rad hose
Greddy bottom rad hose
Shiny coolant expansion tank
Painted spark plug cover (same as car)
Painted strut brace (same as car)
Exterior:
TRD Carbon Bonnet
TRD Carbon Wing
Top Secret front bumper
Toyota side skirts
Veilside wing mirrors
Extras/Gauges/Toys:
HKS Turbo timer
AEM Wideband Sensor
Defi Display with Exhaust Gas Temp, Oil Temp, Oil Pressure, Water Temp & Fuel Pressure sensors
Performance:
Mapping (by Ryan.G) was aborted due to a faulty oil line, a boost leak and some oil burn, which was preventing enough advance being added. However, in this unfinished state it still managed 533fwhp at 505ft/lbs
All of these problems have been sorted (the oil issue was valve guides and have now been replaced), however I haven't taken it back to Ryan to be finished yet, but it should see 600bhp. :)
Looks good - a dyno with AFR's on it will always help settle any nerves about it for a prospective owner ;)
Good point, I'll have to find it....it's in a box somewhere... :blink:
I might get Ryan to finish it, I'd feel happier to sell it on completed rather than 'it should do this...'
Lovely motor and priced to sell imo.
Excellent price for the spec even with the bits that need sorting :thumbs:
Also, what is the resprayed colour? Was it a glass out jobby?
Cheers
Ta. :)
It needs to be seen in sunshine for the full effect as it's a deep graphite, but with metallic flecks of copper and green. :)
It was a complete strip for the respray (Piccy's), everything was off!
Now that’s a nice Supra – As people have already said though, get Ryan on the job and it should literally fly out of the window
EDIT: How many miles mate?
Cheers geez :)
Ryan has done all of the mapping so far (on the original twins and the current single); the road tune is complete and it drives beautifully, the bit that needs finishing is turning the tubbie above 1.4bar.
It has 65k on the clock.
 Share
