Engine turn without iignition
csa
 Share
If you're only doing an oil change, there will still be enough oil on the bores and in the lifters to protect the engine on first start up with new oil. whichever way you look at it, the starter motor's gonna turn the engine over with or without the car starting! Did mine on thursday with no problems! :D
If you really want to do it though, you can pull the king lead off the distributor or disconnect the coil pack.
 Share
