wrenlea Posted June 29, 2008 Share Posted June 29, 2008 Would anyone be able to advise the correct/acceptable torque for the three nuts on the studs at the top of the pipe on a Supra Twin Turbo RZ I am attempting to remove them and having finally got a proper socket I am having to use a torque wrench to get more leverage. I am up to 110 ft Lbs and begining to chicken out Thanks Quote Link to comment Share on other sites More sharing options...
bignum Posted June 29, 2008 Share Posted June 29, 2008 Have you sprayed any lube on them, it will help, 1 of mine was so tight it unscrewed the stud out of the downpipe Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 29, 2008 Share Posted June 29, 2008 My best advice would be to apply constant and gently increasing pressure from a large breaker bar to get some leverage on it. thats in addition to what Bignum says about lubricant of some kind - WD40 is ok, but Plusgas is better, Dont, whatever you do, try to shock it or try to 'bounce' the breaker bar!! They come off with a bit of a bang too! Quote Link to comment Share on other sites More sharing options...
wrenlea Posted June 29, 2008 Author Share Posted June 29, 2008 I have yes, thanks. It's just that having read on here about sheering studs etc I am dreading doing the same. In theory they should come off alright as they were only put on some 50 weeks ago. I was going to give up today but maybe if I spray more on now and leave it 24 hrs it might be easier. At least that will give me at least one more use for my 14mm deep socket. Quote Link to comment Share on other sites More sharing options...
wrenlea Posted June 29, 2008 Author Share Posted June 29, 2008 My best advice would be to apply constant and gently increasing pressure from a large breaker bar to get some leverage on it. thats in addition to what Bignum says about lubricant of some kind - WD40 is ok, but Plusgas is better, Dont, whatever you do, try to shock it or try to 'bounce' the breaker bar!! They come off with a bit of a bang too! Thanks for that It does sound as though they are tough so I'll spray some more WD40 and have another go..... Quote Link to comment Share on other sites More sharing options...
bignum Posted June 29, 2008 Share Posted June 29, 2008 I did have to put a short extension pipe on my ratchet to give more leveridge iirc and watch your knuckles when it does crack, Quote Link to comment Share on other sites More sharing options...
