JDModified Posted February 3, 2008 Share Posted February 3, 2008 Need a second opinion. Cobra alarm deactivated, key turned to ignition, no ecu lights on the dash as if there is still no power to ecu, all fuses ok, connections ok. I recon the alarm/immobiser is having a fit, but if you know better feel free to throw some suggestions my way. James Quote Link to comment Share on other sites More sharing options...
Ric Posted February 3, 2008 Share Posted February 3, 2008 if you've deactivated the alarm.. Presumablly by disconnecting it Then imobiliser isnt going to deactivate is it? Quote Link to comment Share on other sites More sharing options...
Sparky Posted February 3, 2008 Share Posted February 3, 2008 I think he means hes deactivated it by pushing the key fob right? Probably the immobiliser problem. Can you lock/unlock the car? Have you done any work recently with wiring? Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted February 3, 2008 Share Posted February 3, 2008 Hey Mate Check that the Main Relay is getting turned on. Plug E10, Pin 24 Should be 12v on that pin. Pinouts are below http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13918&d=1112558155 Quote Link to comment Share on other sites More sharing options...
AndyT Posted February 3, 2008 Share Posted February 3, 2008 Ryan to the rescue.......:d Quote Link to comment Share on other sites More sharing options...
JDModified Posted February 4, 2008 Author Share Posted February 4, 2008 Thanks for the input guys, i got the car started eventually with some higery jiggery hokey pokey with a 12v supply, and managed to confirm the alarm is at fault. Quote Link to comment Share on other sites More sharing options...
