6 Speed GT67 Single Turbo Black
wkdtime
 Share
**REDUCED TO £11995**
Promised I wouldn't do this again, reality has well and truly set in.. http://www.mkivsupra.net/vbb/showthread.php?p=1522060#post1522060
Im still in two minds ATM, So am not in any real rush to sell.
Below is the Spec
History
It's done just over 56000 miles, and has been resprayed from silver to black, I have owned the car for two years and am the first UK owner, it was imported via a UK importer.
The car has always been serviced using fully synthetic oil, first year I used Mobil 1 15w50 and for the past year Silkolene Pro s 10w50.
The Single install was carried out by Michel Lane (mkivsupra.net official trader), see here for the thread which documents the install,
This is what I thought about the tranformation from BPU to Single,
http://www.mkivsupra.net/vbb/showthread.php?t=111532
Bad points.
The healdight's have yellowed and could do with a refurb
Around the front and rear windscreen you can still make out the old paint work as the screens were left in when it was resprayed.
The Do luck nose needs a respray.
Interior needs some TLC, new door cards are needed as i was going to do a complete install but obviously plans have changed.
Spec.
Engine/Fuelling
Polished SPGT67 0.68 a/r 4" intake Single Turbo (1 month old)
4" Down pipe (1 month old)
4" Mid pipe (1 month old)
Tannabe RM full stainless steal exhaust
XS Power 3 Row Intercooler (1 month old)
Koyo High Capacity ploished Rad ( 1 month old)
AEM 4" Induction Kit
PE 880 CC Injectors
HKS Copy Dual Flow fuel Rail
Aeromotive FPR
Dual Walbro intank fuel pump set up
-8an Braided fuel lines
HKS external wastegate 1.1 Bar spring
Screemer pipe
MAP ECU
Horse Power freak 900HP rate clutch
Horse Power Freak lightened Fly wheel
Stage 2 Fuelling setup has been used. No short cuts.
The single install was carried out by Michel Lane just a few months ago.
Exterior
Original Evo Explosion Side skirts (£600 supplied by whifbitz)
Do Luck copy Nose
Veilside Rear Spats (copy)
Facelift Rear lights
Wheels/Suspension
19" Racing Hart Cr's with custom offset's (big dish rears)
19x9 front (Falcon 452's 3 months old)
19x10 rears (Falcon 452's 3 months old)
Brand new D2 fully adjustable coilovers both ride height and stiffness.
These wheels are discontinued and set me back £2k with no rubber.
Arches have been rolled to accomodate the rear offsets giving a nice 3" Lip on the rears.
Electronics,
Blitz ID3 Boost controller Limited edition in Black (currently car is running off wastegate)
Apexi El2 EGT (still in box)
Apexi EL2 Boost Gauge
Apexi EL 2 Tacho Gauge with shift light
Aem wideband (1 month old)
EL Glo Dash dials
The car has had a full service done recently,
Oil change
Gear box oil change
Coolant change
The car has been dyno'd at 1.4 and made 560 ATF,
It has since had a retune and made just shy of 500 ATF on low boost off the wastegate 1.1Bar (Dyno graph provided)
Since then I have been running the car on low boost and its amazingly quick even at 1.1 Bar.
You can turn the boost up to 1.4 and easily attain 550 BHP plus.
The fuelling setup is good for 800BHP (Alot of money spent in this area)
The car comes with 2 Months Tax and 10 months MOT which it just flew through.
Absoulte Bargain with the Spec I have.
Contact via PM only serious buyers please
Videos of the car.
http://uk.youtube.com/watch?v=roaVZwK
http://img217.imageshack.us/img217/1457/dsc00491ow1.jpg
http://img264.imageshack.us/img264/200/dsc00496um8.jpg
http://img134.imageshack.us/img134/4628/dsc00159ym4.jpg
http://img246.imageshack.us/img246/6950/dsc00002ig8.jpg
http://img59.imageshack.us/img59/7586/dsc00003kh3.jpg
http://img130.imageshack.us/img130/8501/dsc00045oi9.jpg
http://img458.imageshack.us/img458/4618/wheelsnz8.jpg
http://img458.imageshack.us/img458/4223/dsc00027wk1.jpg
http://img73.imageshack.us/img73/1237/dsc00052ud8.jpg
http://img135.imageshack.us/img135/1169/spa0176ai8.jpg
your fuel lines are -8an not -4an .. AEM original filter, this car has excellent spool , i think its perfect for a 6speed street machine. The spool starts at 2000rpm and full by about 3500rpm , the power curve is very even and very manageable. Its a perfect car once the smaller points have been ironed out, as pointed out by adnan.
Shame you are selling it , you were enjoying it so much !!.get rid of the girlfriend ......
 Share
