ground and power 12v where?
patrik
Hello,
im installing a sld (greddy) but have not a clue where to put the black cable and where to put the red 12v cable.
im down at the main ecu and has connected it in on pin 2 (speed sensor) and now only need power for the device.
dont really want to cut more cables (if it can be avoided).
any tips?
Okay, if you are down in the ECU area using the SLD.. Then I would suggest using the wiring from the ECU rather than running extra wiring all the way up to the odo/clock.
There is a pinout diagram on this site, if you have a look for it. If you don't come right, buzz back, and I'll dig out the pin outs for you.
i found the diagram and i have guessed at pin 33 labeled battery
as a source for 12v ?
and 79-80 as the ground to put the black cable?
is there any other source around the main ecu one could get
power and ground (since the cables in to the ecu is really tightly spaced).
