chris aka fonz Posted March 13, 2005 Share Posted March 13, 2005 Hi , my tt supra is de catted and boosting to 1.2 bar , i notice that the fuel is cut and there is no power there sometimes when i put my foot down , Do i need a fuel cut defender , and if so which one should i get ? Link to comment Share on other sites More sharing options...
hadyn Posted March 13, 2005 Share Posted March 13, 2005 yep, thor do a good FCD Link to comment Share on other sites More sharing options...
Homer Posted March 13, 2005 Share Posted March 13, 2005 If you're hitting 1.2 bar then either your gauge is misreading or you already have some sort of FCD fitted. Stock cut happens at (I think) 1 bar, the Thor cut happens at 1.25bar. Assuming your gauge is accurate it sounds like you already have the Thor unit fitted. Does the power cut suddenly (violently) only at high boost for just a split second? Is this happening at low boost levels or for prolonged periods (more than 1 second)? BTW, do you have the supporting mods done for a full de-cat (e.g. plugs and fuel pump)? Also have you replaced the fuel filter recently? Link to comment Share on other sites More sharing options...
