SteveC Posted November 6, 2005 Share Posted November 6, 2005 Whilst re-setting the air bag light in the diagnosis connector (Data Link Connector No1) on the left hand side of the engine compartment, I noticed a small wire link between WA and WB. I find it hard to believe that this link is supposed to be there under normal running conditions. Has anyone any idea what this link is for? I've done a number of searches but I can't find anything. Thanks, Steve. Quote Link to comment Share on other sites More sharing options...
SteveC Posted November 10, 2005 Author Share Posted November 10, 2005 I eventually discovered that the same link on a Camry is for the ABS and should be present. I assume that this is the same for the Supra. Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 11, 2005 Share Posted November 11, 2005 If that's the metal bridge in the bottom right corner of the diagnostics port then yes, it is supposed to be there. It comes out to put the ABS and TRAC system into diagnostics mode. -Ian Quote Link to comment Share on other sites More sharing options...
