Kaaz DAT3020 LSD
Alex_GT
 Share
http://www.kaazusa.com/lsd_toyota.html
Their website lists the DAT3020 as fitting the 96.06~onwards JZA80 Supra. All J-spec Supras post this date (NA, TT, Auto, Tip and 6spd) were fitted with the smaller A diff. The axle code on your VIN plate should start with an A if it does and it has the original diff fitted then according to the website it should fit. See here for an explanation of the axle codes http://mkiv.supras.org.nz/specs.htm
Only the pre 96.06 TT 6spd Supras were factory fitted with the larger B diff.
  • 2 weeks later...
 Share
