TT auto box part number question
and1c
 Share
Ok, I bought a new Auto TT ecu as I thought this was causing the fault codes and weirdness I have been experiencing.
The replacement ECU for mine (1993 jspec TT) has a different part number...
I have on Supraforums and found this
ECU Identification Numbers
I've located all this, but does anyone know the numbers for the US-spec TT Auto 96-98 Supra ECUs?
Aristo ECU Part Number:
- 89661-35060 (91-93)
- 89661-30870 (93-97)
Supra ECU Part Numbers (Auto, J-Spec, NA):
- 89661-14600 (93-97)
- 89661-14810 (97-99)
Supra ECU Part Numbers (Auto, J-Spec, TT):
- 89661-14490 (9305-9310)
- 89661-14491 (9310-9605)
Supra ECU Part Numbers (5Spd, J-Spec, NA):
- 89661-14610 (only number listed)
Supra ECU Part Numbers (6Spd, J-Spec, TT):
- 89661-14500 (9305-9310)
- 89661-14501 (9310-9605)
- 89661-14770 (9605-9709)
- 89661-14830 (9709-)
Aristo ECU (JZS16#)
- 89661-3A470 (9708-0007)
- 89666-30180 (0007-)
The ECU part number depends on the age of the car.
2JZ-GTE engine
jzs=Aristo
89661-30510 = JZS147..Q Oct 91 - Aug 93
89661-30750 = JZS147..Q Aug 93 - Aug 95
89661-30880 = JZS147..Q Jul 94 - Feb 95
89661-3A180 = JZS147..Q Aug 95 on
2JZ-GTE engine
89661-30560 = JZS147..V Oct 91 - Aug 93
89661-30870 = JZS147..V Aug 93 on
My original ECU that I am trying to replace is 89661-14490.
That is the correct ECU for the car.
The replacement one I have is also labelled as being for a 2JZ-GT A/T but (and the label is worn so I can only read part of it
8***1-146**
Now, I can only see the NA auto ecu that has a 6 as third digit in the second number. Mine is 100% OEM labelled as a GT ecu and the numbers above are right!! Anyone got any ideas what its from?? I have googled my ass off and can't find anything. I am wondering if it is a superceding ECU of the original??
Instead of a large 89 label it has a yellow label with 06 on if that helps anyone...(depending on which way you read the label, so it could be 68 and 90 respectively!)
cheers
 Share
