Guest rockabilly Posted December 9, 2007 Share Posted December 9, 2007 hi guys, not sure if this is my first post as i have had to register again.. i am after some help and you guys are it:) just built myself an rb30 ozzie block with rb26 head.. now i know some of you guys use the gt35r blower so with the specs below what bhp/torque would you suspect it may create and at what boost.. also what is the boost limit on this turbo 2bar?. i ask this as not many skylines run 3.0ltr blocks so the guys on there dont really know..cheers bernie.. specs.. 3.0ltr block,,bottom end balanced. cp forgies, spool forged rods,acl bearings. arp crank/rod head bolts. 264/272 cams 9.7mm lift. twin tomei fuel pumps,1000cc,s and hks reg. gt35r on 6 boost amnifold, tial 44mm ex waste 1.06 rear housing, 4" dump. exedy triple plate clutch, link to rebuild..al done at home.. http://s212.photobucket.com/albums/cc220/rockabillyrb30/ Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 9, 2007 Share Posted December 9, 2007 I would go over onto the SXOC and ask there as there are at least two people who are running RB30 lumps in their 200SX, plus the guy who started it all in NZ is occasionally on there. Link to comment Share on other sites More sharing options...
Nic Posted December 10, 2007 Share Posted December 10, 2007 Dyno of my car running GT35R (AR .82, T4), in256/ex264 at 1.2bar http://img508.imageshack.us/img508/7601/542hpdynodu3.jpg Link to comment Share on other sites More sharing options...
steb9780 Posted December 10, 2007 Share Posted December 10, 2007 Get in touch with RB motorsport, they know all about the RB30's, they are local too. They are in Mawdesley near Croston IIRC. Link to comment Share on other sites More sharing options...
